John in CR said:
Also, the route to extreme power with a HubMonster is high voltage. Once you get above 150A battery side per controller pushing an all up load of 200kg, you need to watch your load, gearing, and how you ride or you can run into heat issues with a stock motor. The more aggressive you ride the more risk of a long hill causing issues. OTOH HubMonsters are perfectly happy running well above 120V as long as you don't gear too steeply. My dream is the day we can get cheap controllers that can handle a real 200v and 200A battery side with 300A phase limits. Since I've already been to over 180kph, that will push me well past 200kph, but the real performer would be taking it out of wheel (ventilated of course with a filtered air intake) and gear it down to 100-120kph and feed it with a quite conservative 50kw. At 125A x 2 and 200V at that kind of gearing, as long as you keep the all up load below 250kg or so with that kind of gearing you could ride as hard as you want and climb anything without drive system stress as long as your battery lasts. Riding without repetitive hard accelerations or long steep hills, you could easily go to 60-70kw with 200V controllers for incredible showing off ability when you want.
Over 100v and FOC is expensive. For example that Australian company with the funny name. I tried to buy a couple of theirs some time back and nearly dropped my jaw on the floor over the price! I've been watching the various VESC projects all claiming 150v and wow...look at them all not going anywhere! LOL! I think the PowerVelocity Project might see the light of day the soonest. It has potential of 200v or more. There's no real limits to 150v in the design that I see. I wonder why Nucular doesn't go above 100v? They are way ahead of everybody else! I'd buy them if they made them.
There is an option that is not outrageous. You get the inverter module from a hybrid car and one of these. Who cares if you run the IGBT's at well under their voltage limits.
https://openinverter.org/docs/index.html%3Fen_home,3.html
My motor...It's seeing 309 phase amp peaks at 82v that's 50kw now. I see 200 amps in them pretty commonly at 82v or 32kw. The venting makes that possible. Without it, I can't run but half that hard. I've replaced my 2 weakest battery packs with much larger ones. I was seeing random power cutouts at 250 battery amps per controller or 41kw so I think that's fixed now. I also upgraded the rest of the electrical system so that it can handle 300 amps continuous per controller. This is the upper limit that Nucular claims. I'm going to be seeing 50kw a lot more often now I think. I'll also add a large heatsink under the 2 controllers to aid in their cooling. I discovered a controller issue with Nuculars thanks to my build. 2 in parallel will create some interesting back feed issues that blows up the logic boards. My last two 24 fets went back to Russia and I recently got replacements. They got set up last night. Vasily and I have been talking about a protection circuit to stop those small electronics failures from ever happening. I have the parts, just waiting on the proto board to arrive so I can build it. I need a BMS for one of the packs so they are all XiaoXiang BMS's, but the electrical it otherwise golden. That BMS is on order...
I'd really like to build at 32S or higher, but there's things I can't do...like invent controllers. I can build the battery pack and 32S or higher BMS's are pretty common. No problems there. I guess I'd need to find a 150v DC-DC too...can't really make one of those either. Oh yeah...and my paycheck is only so big so I can't afford the expensive stuff either!
When you say gear too steeply, a 12" wheel and tire ought to be OK right? The Zap had a 10" wheel on it originally, but then I saw somewhere on here that the RMartin has 12" wheels so I replaced mine with 12". This is OK right? I mean longer term when/if I upgrade to higher voltage? My back tire is 120/70-12. I'm pretty sure that's what I saw on that RMartin. This better be OK! LOL! I bought 12" cast wheels and then machined one of them to fit my motor. Looks super nice!
https://imgur.com/YhJLYVa
https://imgur.com/Kqhuxnc
https://imgur.com/ahGRP9c
550 pounds or 250kg all up is quite doable. I guess I personally should lose some weight. I wonder what my Zap scooter weighs? I'll find out once it's all back together again.
I took my swing arm off tonight. I plan to be machining new torque arms over the weekend that clamp to the entire shaft flats. The dropouts won't make contact with the flats anywhere. I'll be machining out the dropouts significantly so the torque arms can carry all the motor load. Just tonight I noticed that my 12" rear tire barely clears the battery box. If I go over a bump, the tire will impact it. I need to move the back wheel out about an inch so it's clear again. I might as well build this into the new torque arms too.
https://imgur.com/Cr8Iddo
