john61ct said:
Would that require DMV registration?
Can't imagine insurance, best save the decorations for after that's been finalised
I don't concern myself with such things. The vehicle depicted above reflects my sensibilities and values. I have no drivers license or id card. It isn't explicitly illegal in my state, that being said. I've even discussed the matter with an attorney, and he recommended not to do anything stupid because the purely technical non-illegality of the vehicle wouldn't be enough to keep the cops away. That legal status could change if ebikes become defined in the legal code, but that won't change my usage of the vehicle. I tend to cruise around 30-35 mph and that won't change as long as I'm using a KMX for a base platform.
With that said, below are some simulation results, with the assumptions outlined.
Laden mass: 120 kg
CdA: 0.06 m^2 (new body shell planned. The current one is at least 3x this value)
Crr: 0.008
Pedal input: 500W (full effort)
Drive wheel: 20" diameter
72Vnom battery pack
4kW limit with 150A phase current, I get the following:
0-30 mph 4.4 secs
0-60 mph 15.7 secs
1/8 mile 11.9 secs @ 52.3 mph
¼ mile 19.5 secs @ 65.3 mph
Top speed 71 mph
8 kW limit with 250A phase current:
0-30 mph 2.8 secs
0-60 mph 9.9 secs
1/8 mile 10.1 secs @ 60.3 mph
¼ mile 17.0 secs @ 67.8 mph
Top speed 71 mph
10 kW limit with 250A phase current:
0-30 mph 2.6 secs
0-60 mph 9.2 secs
1/8 mile 9.8 secs @ 61.1 mph
¼ mile 16.7 secs @ 68.0 mph
Top speed 71 mph
As I get stronger, the bike will get faster. If I were to do a bunch of squats and train like a pro athlete to get to the point where I could squat 300 lbs at my 140 lb weight and make about 1200W at the pedal crank for ~15 seconds at a time, I could get significantly faster, especially considering the acceleration from the motor starts to reduce dramatically after about 45 mph.
8 kW limit with 250A phase limit and 1200W pedaling:
0-30 mph 2.5 secs
0-60 mph 8.7 secs
1/8 mile 9.7 secs @ 62.1 mph
¼ mile 16.4 secs @ 69.8 mph
Top speed 71 mph
10 kW limit with 250A phase current and 1200W pedaling:
0-30 mph 2.3 secs
0-60 mph 8.1 secs
1/8 mile 9.4 secs @ 62.7 mph
¼ mile 16.1 secs @ 69.9 mph
Top speed 71 mph
Also, there are ebike controllers that can go to 130V, but they don't have the features I'd like. If an FOC controller of about 2 lbs were to come onto the market that could do 130V and output at least 250A phase current(such a controller may be out soon in fact), and I were to pedal with 500W instead of 1200W with the motor limited to 10kW, we get the following results for the ultimate theoretical configuration with this motor:
0-30 mph 2.5 secs
0-60 mph 7.4 secs
1/8 mile 9.0 secs @ 74.3 mph
¼ mile 15.0 secs @ 84.7 mph
Top speed 118 mph
All of these results are very car-like. Not bad for a cheap Chinese motor in a vehicle that can still be operated purely on pedal power even faster than a triathlon bike in most settings. I wish they'd make a better motor that was lighter, more efficient, less lossy, could handle more applied power, and used a stronger design for the freewheel/cassette placement and axle. Imagine the 1000W 3T version of their motor set up as such with ultrathin 0.05mm lams, stronger magnets, and able to handle 15 kW peak @ 72V. If that kind of power could be pushed to the motor, 0-60 mph would be under 6 seconds and top speed into the 80+ mph range, and I'd really like to be able to screw around with fast cars at stop lights. The existing 1500W motor you can buy will merely keep up with normal cars, which still would be impressive all things considered.
