amberwolf said:If it's pretty different, you may need to play wiht the Beta coefficient / value and offset in the CA settings to match yours, which might not take long if you use a "half / double" approach. (halve the value and see if you're closer or farther by a lot; if it's the wrong direction then double it instead. If you're closer, halve or double again, and so on, until you get within what you consider close enough, at room temperature and a "hot" temperature of your choosing. )
It's a lot easier than opening up the motor.
I'd be OK if there's a display of any kind that could read and display the temperature, but having it work with the CA would be great. Unfortunately, when I measured it earlier, it was 600 ohms at room temp. I see a few on ebay with a coefficient of 3950, so right in the middle of the range that the CA accepts, so I'll order one or two of those. Didn't want to open the motor, but I figure I might as well take care of that and the Statorade before mounting it on the bike.
