Bafang (assume hub) motor in suspension (aluminum?) fork is a touchy setup. Lower power Bafang and GOOD torgue arm may make it safe. But 45 mph on that rig you propose will be hairy.
Yea I know.
I think it was early spring but could have been last year I snapped the drop outs with a Bafang. My solution was a three step process.
The first was to look for steel which the Diamondback Outlook is as a magnet stuck. I replaced the forks that broke on the Currie but still aluminum. Better than the ones that broke though. The 26" dual suspension is also aluminum but also thicker then the ones I broke. It is a royal pain in the arse. It is why the front direct drives I bought are on the back. NOT the front.
The third step is re learn how to use a thumb throttle. That is done with the wheels suspended so zero load. Then practice how to spin the wheel slowly. It takes a real light touch. that piece of advice is good for anyone who reads this post. It can also save a lot of broken drop outs in the future. It is good practice for any motor on any wheel chain or hub to test at zero load but especially any front hub motor.
That said I ran into a few situations where a torque arm is needed but impossible to mount. Well maybe not impossible but would take something special. Might need a machine shop.
I took a short cut to isolate the axle nuts by vice grips so they stay as tight as possible. You do not want any room for that hub motor to snap the drop out. Any play could risk failure. and in one case I used a ratchet and socket and the steel clamps that come with standard torque arms. :lol:
The local bike shop did not want to touch it and called it sketchy. First time I heard the expression and now I use it all the time. :lol: Those are things I need to address when I start my new , good , professional , clean also tricked out I think Tomajsz said. builds I plan on doing.
I cant take short cuts or do sketchy shit on a GOOD build. I realize that. I probably should have steel forks with every e bike with a front hub. The Giant Roam does not have front steel forks. They are aluminum as well. That is why that throttle trick is important. Probably the best advice I came up with. Sure someone else thought of it first but I do not know who. It was my idea. I did not copy anyone.
I am working on the LTOs. My Wall Mart cutter works good. Connecters work. I have to count everything to see if I have enough. I still need solder. I have none.
Taking my time on the LTOs. I am posting a video now.
https://www.youtube.com/watch?v=SrXIpsxoHBU
The SLAs on the top I need to measure. Was going to put them on top of the 12S packs under it. 60 pounds on the top bar is too much. BUT It I can mount the SLAs on the lower bar and still have enough room on the top bar for the LIFEPO4 it could work . I doubt it but will measure the Currie. I got plenty of wood to build it smaller to fit over the bottom bar.
I have everything I need for the LTOs. I am going slow and testing each connection before and after. I will tape over the cells that I do so I don't drop something on them and short them out. I might cut out card board squares. I have panels cut but need to screw them in when they are finished and ready to charge.
Solder is all I plan on spending this month. I need to save money to move. At least 2,500 put away. Then I can order the prismatic cells. That could happen by next month this time if I don't get stupid. The 20" bike with the 1,800W brushless motor is a great e bike to work on this month and wont cost any money. I went cheap on the 1,500W brushless controller. 48V. I might hook up the 3 kilowatt 70 amp 60V controller and run all 24 - LTOs. Then if it will do 35 mph I wont need a brush motor on the front.
Thanks.
LC. out.
