tmho
I have finished adding PAS to my e-bike and is working okay. I want to add a switch to turn PAS off when I do not want PAS. My plan to do this is to add a switch to one of the 3 wires of the PAS. Is my plan feasible?
Below is the photo of my diy cable to be added in between the sensor and controller in order to turn off the PAS. The plug with red wires will go to the on/off switch and the other 2 plugs to the controller and PAS sensor. But I could not get the PAS working when hooked up. What is wrong?
(I have checked the resistance of each wire of my diy cable between the 2 end plugs. They are all about 1.9 to 2.2 ohms. I have also plugged the diy cable to the controller side and the switch only and found the voltage at the other end of the diy cable is 4.73V between the power and ground, which is the same on the controller when the diy cable is not plugged in.)
