The Madmadscientist
- Joined
- May 29, 2022
- Messages
- 93
E-HP said:
Unless you're building a mid drive. you'll never use that 50 tooth cog in the rear. I'd be surprised if you use anything more than about 26 to 30 teeth in the rear. Any bigger than that and you won't be able to pedal fast enough to keep the motor from bogging down and frying itself...unless you can pedal like a hamster. With 60 front and 26 rear and 80 cadence, you'll be going 15mph, which is a good speed to avoid meltdown when climbing a hill. With 50 in the rear, you'll be going 7.5mph, so too slow, so you'll never use it.
I use 46:16 for climbing hills, 46:18 if it's super steep. That would equate to 21T and 23T rear when using 60T front.
I'm thinking about my fat but on a heavy bike starting from a dead stop at a light...
I'n new to proper gear ratios for ebikes...well honestly having ridden bikes for years I've never really thought about gear ratios until now.
