john61ct said:It is very rare for those who speak English to have much technical knowledge.Reecew89 said:Just curious as QS Motora said i need a higher T count for torque which i understand but i have enough power to send to generate torque i need well i thought anyway.
Achieving your desired top rpm later in your throttle range helps with efficiency,
and higher voltages are a bit better for acceleration, but less efficient at low speeds
in general, when you change the winding, you ONLY change what ratio of voltage to amperes are needed to make a certain amount of power.
https://endless-sphere.com/forums/viewtopic.php?t=108781
https://endless-sphere.com/forums/viewtopic.php?p=1592954#p1592954
https://endless-sphere.com/forums/viewtopic.php?t=109082
https://endless-sphere.com/forums/viewtopic.php?t=105510
https://endless-sphere.com/forums/viewtopic.php?p=1557363#p1557363
https://endless-sphere.com/forums/viewtopic.php?p=1578274#p1578274
https://endless-sphere.com/forums/viewtopic.php?t=106117
https://endless-sphere.com/forums/viewtopic.php?p=1577684#p1577684
https://endless-sphere.com/forums/viewtopic.php?p=1670686#p1670686
https://endless-sphere.com/forums/viewtopic.php?p=1670083#p1670083
https://endless-sphere.com/forums/viewtopic.php?p=1666676#p1666676
https://endless-sphere.com/forums/viewtopic.php?t=111924
https://endless-sphere.com/forums/viewtopic.php?p=1653764#p1653764
https://endless-sphere.com/forums/viewtopic.php?p=1650700#p1650700
Thanks for the reply much appreciated.
So same question i asked above,
I am curious if i can push enough power before damaging the motor to get my desired torque failing that ill buy another motor ie a 4t or 5t?.
