Hello everyone,
I recently started my second ebike build and got a Sabvoton 72150 with QS V3 275 motor. However, after studying the connections further I've came to the conclusion that motor and controller HAL connectors are incompatible (or am I looking at the whole thing wrong?). Could it be that supplier screwed up and made a mistake with the kit?
Photos with connectors:
https://ibb.co/pXjkRsW
https://ibb.co/HdtXD6s
https://ibb.co/Dbh2MGJ
I see a potential solution in replacing the connector on the motor manually by pulling the pins out and attaching them to the controller, however I'm not sure if that's a good idea. I could order a male version for this connector but don't know the name of it. Does anybody know the name for this connector so I could order it online?
Also I noticed that on the motor there is an extra white/transparent wire, which doesn't have a female counterpart on the controller. What is that wire used for?
Thanks for the support.
Sam.
Sam.
