mnplus1556 said:
so i've hear that you can figure out how fast your e-bike can go with a watt to mph ratio. i've hear of 3200 watts to 40 mph. i've also hear 450 watts to 25 mph. these seem like really far apart ratios to me. so does anyone know the correct ratio? i'm just trying to figure out how to gear my bike with a 1000 watt motor (36v)
thanks!!
To know how to gear the bike with a particular motor at a particular voltage, you need to know how fast you want to go, how fast the motor spins with a load at that voltage, and then calculate the gear ratios for whatever reduction stages you are going to use between motor and wheel to get the wheel to the speed that equates to the desired road speed.
Now, if you gear for the fastest possible speed from a motor, you may sacrifice startup torque, and then end up having to always pedal up to a certain speed before the motor can safely (or at all) start moving you on it's own. If you are always going to pedal with it anyway, that may not be a problem, If you wnat to run without pedalling, though, you also have to consider what startup torque the motor will end up with at your gearing.
If it is possible, running thru the bike's regular drivetrain will give you the best of both worlds, since you can shift down into granny gears if necessary for hills and startups, and back up into racing gears for speed, just like when you pedal. Some bike's geometries or component layouts make this difficult, depending on teh motor you have.
As for the topic title, there is an interesting thread that is a survey of what people are actually getting for watts at various speeds:
http://endless-sphere.com/forums/viewtopic.php?f=5&t=14786&start=0
which may help you figure out what you want, too (for those that gave build links and stuff).
