zombiess
dbaker said:ZombieSS,
Post some measurements and desired enclosure details. There might be a way to use available boxes, perhaps joining several to get what you need without a custom machine shop solution or at least reduce the machine shop hours.
I already have the mechanical side figured out and the pieces to assemble it. Its big but this is my first revision. Next one will be MUCH smaller.
I have 6x6x0.125" alum square tube 12" long for the enclosure. Heat sinks are three 1.5"x0.125 U channel 6" long. I have spacers to join all the boards together into a solid unit that can withstand vibration. What I need now is 24 holes, 8 on each one side of the U channel to mount the FETs and then mounting holes on the opposite side in a pattern to match up with holes in the square tubing.
Anyone who works with metal would laugh at the simplicity of this. I estimate it would take a pro about 30mins start to finish because I could do it in about an hour if I had my mini mill working...it's still sitting in the crate it was delivered in 6 months ago all sticky with cosmoline.
