edit: The MAC geared hub is has reasonably LOW eddy-current (which causes waste heat, even when unloaded) up to above 1,300-RPMs. The lower pole-count Bafang should be able to be run up to more than 2,000-RPMs while still having low eddy-currents. So, you can spin the Bafang roughly twice as fast as the MAC, and then you can externally gear it back down to the same wheel speed. This has the effect of the Bafang being able to perform as though it's twice as big as the MAC, in regards to max power capability and ability to put out that power while staying cool. Also, the Bafang is roughly half the price of the MAC...
I've been following crossbreaks conversion to make the axle spin, I believe it's a very important development. There are minor variations inside the geared hubs, and I was relieved to read that the MAC from cell_man not only worked, but was easier than others that were tried. The MACs not only had a low-Kv 12T on the shelf right now, but if someone wanted to use a faster winding, he already has five different Kv's (many manufacturers only have two choices of Kv).
The Bafang is available and affordable, so I was also glad to see that it "looks like" it will take well to the conversion. The Bafang has fewer poles, so it will be the model of choice for those who want to use a faster winding and then use a large external reduction to make the RPMs useable (off road?). The higher pole-count of the MACs make them smoother when using a sensorless controller.
Since the converted motor-shell would now be stationary, it opens up a whole new world of easy fat phase wire upgrades, and active cooling mods.
