tri-lobe
Hey members..
This post is for members who don't know about getting precision fits on pulleys and shafts.
I earn my living as a machinist....and as such i do not consider drilled holes as precision for mounting drive gears/pulleys...
I drilled the 18t pulley to 14mm id, then useing a boreing bar machined hole to 15mm...measuring with telescopic guages and mics....as per normal turning proceedure......so the id is correct......
The shaft is turned down....measuring with verniers first....finnish measuring with micrometer.....so the od of shaft is correct..
Now....pulley id @15mm.......shaft od @ 15mm.......a light rub with emery paper....and we have,for our general purposes ..a nice true sliding fit......
A reamer is a precision tool....a drill is normally not.....unless you have a drill kit that progresses by .1mm increments.....
a couple of thou clearance is sometimes a couple of thou slop........I could not hand this over to the customer......
But the chinese can and do.....yeh it was cheap......nasty and cheap.......whats a couple of thou????
The run-out on my 80t ally pulley is a prime example of the above......
I accept the lower quality for the cheap price......knowing that i might have to "tweak"...code-word for re-work....an item or two...
my chinese lathe and milling machine are no different.....i had to "tweak" them...to be user-friendly...over time...
So members.....a very merry festivest to all.......
