Waynemarlow
There is no point disassembling the engine as the cable is very short directly into the controller.
I have found sometimes that I couldn't program the unit and had to read only each part of the memory individually and program each part individually. Checking the checksum each time with the loaded program.
The other thing which I have never fully gotten to the bottom of is the read write data bit has to be changed, on some of the engines its no problem, on others it won't change and then suddenly it changes and never again is a problem.
