casainho
10 GW
- Joined
- Feb 14, 2011
- Messages
- 6,045
I don't know if I understand well. You mean that motor max out the assist power at low pedals RPM and the user will then need to increase his pedal torque to get more speed? that is strange for me... I would expect to get help from the motor up to the defined max wheel speed. And with direct drive that will not work -- in fact I need to work more on the direct drive part as I am not totally happy with the results, like motor blocking/braking/regen when I pedal over the motor max speed...stancecoke said:The ramp just should give a smooth start up, but then the motor-torque should stay constant and you can adjust the speed with your human power. That's the origin idea of the "torque-simulation" mode.
I can implement that. Can you please specify that values again as I think you are not considering that we have value for assist level of: 0, 1, 2, 3, 4, 5 and I think is more intuitive to put 0% output with assist of 0.stancecoke said:Perhaps we should give the user the possibility to set the steps of the PAS levels by himself, e.g.
Level 1 = 0%
Level 2 = 10%
Level 3 = 20%
Level 4 = 50%
Level 5 = 100%
