Ok, thank you. I will keep reading your work that you share here. Thanks for sharing.walls99 said:Hi Casainho,
I'm afraid you are a bottom of a steep learning curve and I don't really have time to help you with the basic principle of sensorless BLDC control, there is a lot literature out there for that. I'll keep an eye on your progress here and help if I can.
Thanks.
I am reading your firmware V1.1 and I want to learn with it. Some years ago I wrote code in assembly for PICs and AVRs, it is nice to read your code and remember those times and also see how you did you resolve the questions about BLDCwalls99 said:bearing said:Is this the latest version of the projekt?
I would like to play with this, and then maybe make a board which can drive a 80100 on 80V.
No, it's quite out of date. I'm planning on releasing new soft but I haven't had the time to finalize everything I wanted. They are many upgrade to handle "high power": Torque control, automatic advance timing, sensorless startup, temperature control, regenerative braking...
I've sent you a PM to discuss alpha release, if you're interested?
casainho said:Hello Laurent.
Could you please tell me what is:
1 - the meaning of AUTO_STEP and STEPPING_ON flags on BMC_STATUS variable? When they are 1, what system is supposed to do?
2- Windmill strategy for start-up you mention on the code is the same as you explained here? http://endless-sphere.com/forums/viewtopic.php?f=30&t=36479&start=15#p534016
Thank you.
Ok, thanks.walls99 said:The "Windmill" strategy start-up relies one the motor already rotating and simply waiting for a few ZC to synchronize the timing loop. This requires the user to push the motor/vehicle to start.
This is not implemented on the latest firmware V1.1 you shared, right?walls99 said:The start-up by position/current sensing is an active way to start the motor by exciting the motor as if hall sensor where used.
I am looking at the schematic components values, as I am trying to understand it better and make a BOM. I am thinking if I can invest on this board/project and use it to control my electric bicycle of 48V and motor of 500W (but for start I will test with my old system of 24V and 250W motor). Do you know if this board/system is able to control my motor of 48V (Q100 350W motor)??
If I invest, I will need to do it also for buying a PICKit2 for programming and debug the firmware, as I will want to make the firmware in C and not assembly as you did. I will develop on Linux. I will also add the Bluetooth module to UART RX and TX lines.
How did you produced your PCBs? Do you have experience with a service for PCBs? Can you recommend a service for PCBs?
Thank you. I were reading your assembly code and I did understand a few more things, but is hard. I changed my ideas and for now I will go with hall sensors, is much more easy and will also let me understand better how all this work/should work.walls99 said:You will have to make a few software and hardware adjustment to run my design at 48V. It's currently set up for 30V and use IRLP3034 instead of IRFP4368. However this e-bike hub motor is not really difficult to drive and can't handle 100A, so you are probably better off using an simple e-bike controller...
For my PCB, I use PCB-POOL.
walls99 said:I was also planning to use position sensor to have full start-up torque but I found that position sensing by current measurement works very well with this type of motor. The permeance varies significantly from one electric position to the other and the permeance is minimum for the electrical position that is aligned with the mechanical position. Also with this type of low inductance motor, the 6 positions scanning is fast enough not to reduce the starting torque (~500us in my case). This approach gives me ~90% of the full potential star-up torque at 5ms sampling rate and it's good for speed up to 100RPM where the BEMF is strong enough to detect Zero Crossing...barryfzr said:I had decided to go down the sensor route though with an Austria Micro Systems As5040(or lower spec 8bit output) which can provide the commutation signals direct.
See below the position sensing cycle, the current is maximum when the permeance is lowest:
On my motor Cute 85, 24V, 250W, I can energize it by 100us and found the position of rotor/sector. Interesting is that my results are a bit different from yours, because energizing 100us I only get current on 2 sectors (one getting more current than the other). Using like 500us I will get current in all sectors however the current on the 2 aligend/"strong" sectors will be to much high!
Thats a great picture its neet to see the inductance slowly letting the amps climb. What is the strait up and down spike on the current that is lined up with a small spike on the gate after the on and off time??casainho said:walls99 said:Here is a screenshot of my scope:
Yellow: current signal
Blue: mosfet gate voltage
I am learning here... but seems that I can identify the correct sector by measuring the highest current. If it will work, I will be more than happy -- my target is to start the motor without having the BEMF circuit working.bearing said:Do you need to get current in all sectors? isn't it enough to get high current in one sector?
I don't know. I am using KU63 controller and external board with microcontroller. See here the schemarics:bearing said:Do you have a 25V gate drive?
I don't know but I used this code:Arlo1 said:What is the strait up and down spike on the current that is lined up with a small spike on the gate after the on and off time??
while (1)
commutation_sector (1);
delay_us (100);
commutation_disable ();
for (i = 0; i < 50; i++)
delay_us (100);
Arlo1 said:Thats a great picture its neet to see the inductance slowly letting the amps climb. What is the strait up and down spike on the current that is lined up with a small spike on the gate after the on and off time??
casainho said:I don't know. I am using KU63 controller and external board with microcontroller. See here the schemarics
casainho said:I have one question: can you please tell me what kind of power switch for protecting over current are you using? Like on this image you shared before:
Great! I was just asking you about the way you put the heatsink on the mosfets. That way, is the LM50 temperature sensor working? Seems to me that is far and not in contact with the heatsink and the mosfets...walls99 said:In the mean time I took a few pictures of the power stage while it was out:
My design has good heat conduction (lot of coper re-enforcement) and a large enough thermal mass that the temperature sensor doesn't need to be on the heat sink, the entire controller heats up and the LM50 picks this up with just a little big of lag.casainho said:That way, is the LM50 temperature sensor working? Seems to me that is far and not in contact with the heatsink and the mosfets...
Thankfully not! I used a lab power supply during the development, now it's stable enough that the on-board OC software handles the shorts. The MCB is more to protect for shorts before the controller which could cause the scooter to burn up. My pack is made of 7x A123 batteries in parallel to have enough capacity but that means a pulse discharge of 840A, I've already "vaporised" connectors because of that...casainho said:Did you saw already the 100A MCB working? During the development, how did you protected against short circuits/over current?
I would like to know what voltage are you working with. I can't understand the voltage and amps of your battery. And can you please tell me what voltage and current does your lab power supply do?walls99 said:Thankfully not! I used a lab power supply during the development, now it's stable enough that the on-board OC software handles the shorts. The MCB is more to protect for shorts before the controller which could cause the scooter to burn up. My pack is made of 7x A123 batteries in parallel to have enough capacity but that means a pulse discharge of 840A, I've already "vaporised" connectors because of that...casainho said:Did you saw already the 100A MCB working? During the development, how did you protected against short circuits/over current?
