Ron Paul's Blimp
- Joined
- Jun 12, 2017
- Messages
- 87
Hi what's the latest known-safe version? Is v20.1C.2-update-2 good to go? Or should I go one earlier? Thanks!
That is the latest.Ron Paul's Blimp said:...v20.1C.2-update-2 good to go? ...
Elinx said:That is the latest.Ron Paul's Blimp said:...v20.1C.2-update-2 good to go? ...
If a build isn't tested well enough, it is named "experimental" or "alpha"
If a build did give problems after releasing, it is withdrawn.
Hi. I'm having similar problem, except that I managed to flash my controller with OSF in the past, recently I tried to update the osf version to the newest and all I get is exact same error.Hi all,
I am French, please excuse the automatic translation.
I recently bought and installed a TSDZ2B kit, I try to flash the firmware, but without success so far. Here is a picture of what I did and with what.
I cut an extension cable from the speed sensor and connected it to the STLink V2 following the datasheet plan.
and the schema of the wiki
I checked several times the continuities, the current passes.
I also checked the voltage across the STLink, I have 3.30V between pin1 and pin3.
With the adapter connected to the motor but not to the STLink I have a resistance of 2-3Mohm between the pins.
It's an STLink V2, not a clone, the firmware is up to date.
I configured STVP like this:
I tried STM8S105x4 and x6
But when I try to read the tables I get this message: "Cannot communicate with the device!"
The bike still works normally, but with the original firmware.
I must have missed something, but I really don't see what! I will be very grateful if you point out my mistake.
Damien
After you release rst-gnd you have connected only swim and 5v?Try this, open only STvisual programmer and try to read data if it is fails, there is pop table, on it is written what to do. You should connect RST with GND on ST- link and turn off the STvisual programmer then turn it on, with connected RST and GND. After that release RST-GND and try read memory on the STvisual programmer. For me it helped.
Yes, that is how I connected it first time when I flashed osf (i thought i need all 4) I have done it multiple time playing with settings in java configurator, but now nothing works.Have you tried connecting the SWIM_RST (reset) pin?
On some STLINK-v2 it is necessary.
I don't understand what the display has to do with connecting the STlink.today i've connected my tsdz2 with new display and there is no connection with st-link(same error) but when i connect my old display with new tsdz2 connection has been established with st link.
Hmm i thought LCD has to be connected to tsdz2 via 8pin in order to flash osf? No?I don't understand what the display has to do with connecting the STlink.
The display is only connected to the battery and the advice is to remove or disconnect the battery with flashing.
What happens if you disconnect the display too?
Normally the display is switched off and you flash the controller, that only get the 5V Voltage from PC-usb.Hmm i thought LCD has to be connected to tsdz2 via 8pin in order to flash osf? No?
Disconnecting the display is not helping.Normally the display is switched off and you flash the controller, that only get the 5V Voltage from PC-usb.
So imho there no link with display when flashing.
When you choosing location for ST visual on C: try to type "\STMicroelectronics" and click ok. adsress should look like this "C:\STMicroelectronics"I've tried running as administrator, even tried running in XP SP3 mode (found a thread that suggested this was a potential fix).
No idea why it's doing this. I haven't another windows system to try it on either to see if it's a bug with that version of the software
OK, that worked perfectly. Cheers!When you choosing location for ST visual on C: try to type "\STMicroelectronics" and click ok. adsress should look like this "C:\STMicroelectronics"
Thanks. Typically I cant get ST.com to send me a verification email !I just got it work Upgrading firmware of the ST Link v2 dongle helped. You can do this by using ST Link Utility: STSW-LINK004 - STMicroelectronics
