asje said:Hi Guys, After having driven 2500 km with a 48V TSDZ2 since May 2020 (without issues ) I've decided to give the OpenSource firmware a try. I'm currently already happy with the standard software, but am looking foreward to use the OS firmware.
Bought the 860C and build the DIY bootloader box "https://endless-sphere.com/forums/viewtopic.php?f=30&t=93818&start=3900"
I've set up the to bootloader box to give off 30Volt and connected it to the display but the display will not power on.
Any idea's what might be the problem?
I've measured the all the output pins on the bafang connectors and all the wiring seems fine. I do notice that the CP2102 module gets hot and my computer sometimes gives an error message that the bootloader box is requiring to much power throught the USB port....
PS: Below a pic of the bike i've build.
48V TSDZ2, 17AH battery, Rohloff 14 speed hub, Chainglider & Magura HS33 rim brakes.
Mine didn't work either. I just use the battery to power the screen now when flashing. See photo
