mxlemming
- Joined
- Jul 17, 2020
- Messages
- 1,125
liveforphysics said:eee291 said:Here is a little test in sensorless mode because the motor has no halls.
https://youtube.com/shorts/pLYTusTA7lk?feature=share
About the waterproofing, since I won't use it on a bike I was thinking it would be fairly safe from water inside a lawn tractor.
That was my initial plan anyways.
I think I'll get the CL700 for my car.
In a car you would not want a sensorless system that has equal chances of going backwards as forwards when it begins to get rotor motion. That's a crude sensorless. A good FOC setup will not go backwards for a rotor tooth before it goes forwards.
I don't think this is a fair statement, or it needs clarifying. The Shul controllers run VESC firmware, the exact same firmware as the "state of the art" axiom you've supported, and have access to the same feature set with probably better performance owing to closer replication of the reference VESC hardware.
If you know of any magic feature above and beyond HFI and openloop startup, please drop a hint and I'll implement it in my firmware and offer to VESC.
