Hyena
Curious...
Have you got another controller you can try ?
Have you had a look inside to make sure it's not a mechanical problem ? I guess the fact that it gets stuck drawing 7 amps is odd and would probably rule out that. It almost sounds hall related, but it shouldn't come and go so precisely like that even if one was loose and was vibrating around inside the motor.
If you can sort out the problem before I get mine that'll be good
