Hello everyone
I burnt my hall effect sensors twice in 3 weeks during the hot weather. Just received the Hubsink and statorade delivery and will be installing them.
Since I am replacing the sensors for the 2nd time, is there any higher temperature resistant hall-effect sensors that can replace the 110°C sensors used in hub motors?
I've found this from google which claims to survive upto 150°C. APS11205
I can't be sure if they will do the same job as the datasheet says it's pins are unipolar.
Has anyone successfully replaced the sensors with a better sensor to withstand the heat?
I am also working on a water cooling system that will basically spray cold water over the hubsinks from outside when temperature hits 110°C on the stator. Just a thermal switch, DC pump and an aluminium bottle with heatsinks on it. Although I would rather have stronger sensors that won't die on my way to work everyday.
I have to climb steep hills with a 1000w rear motor and a 1200w controller. I will be filing the shunts of the controller too this weekend.
Thanks for any tips :thumb:
