I have not found na answer anywhere do here the very basic(dumny ) question:
When flashing the firmware the controller schould or schould not be connected:
1. To a battery?
2. To other peripherals like LCD, Pas etc.?
3. Powered on or off?
1. To a battery?
With the Kunteng controllers, if you have connected the 5v +ve from the STlink to the controller you don't require main battery or any other connection to flash.
Does anyone know does the KT controller original software have the feature of power rollback, basically, when coming close to LVC it starts taking less power from the battery?
I am flashing the firmware for junior MTB on 24wheels with AKM 85 motor with torque sensor. What i would to achieve is kimś od soft start do the motor powr does increase over 0.5 to 1 sec. I read the manual but cannot clearly determine which Ramp schould i define and what value pit there. Can you help to specify?
The ramp settings are for "torque-simulation" mode only. With a torque-sensor, they have no function.
For slower respond you have to reduce the Gain P and Gain I settings of the PI-control.
eg.
Gain P = 0.05
Gain I = 0.01
regards
stancecoke
eg.
Gain P = 0.05
Gain I = 0.01
regards
stancecoke
Okay all clear now. :D thanks a lot!
Just run first test. It works just great. I have set the Gain P on 0.10 and Gain I on 0.02. Are those perimeters also responsible for the speed of power decrease?
The lower values seemed to sluggish and we need some reactivity for offroad riding. Tomorrow next test :D
I have set the PAS threshold on 1.5 for Sempu T4 with 48pulses per rotation.
Is it correct given the readouts for forward rotation in BlueOsec (bakward is just zero):?
PAS status - PAS fraction
2,44 - 8/3
2,4 - 9/3
2,4 - 9/3
1 - 7/4
1,68 - 5/3
2,58 - 7/3
1,66 - 8/4
1,77 - 5/3
2,48 - 7/3
1,65 - 7/4
1,66 - 3/1
1,66 - 3/1
2,54 - 5/2
1 - 1/1
Please advise
Please advise
The PAS threshold is irrelevant in torque sensor mode. It's not used in the code.
regards
stancecoke
regards
stancecoke
Okay but then is it PAS irrelevant at all. I though cadence is affecting the power calculation ? so then i am looking for the reson why sometimes the motor does not star from idle. It may takie few to 10 seconds before it start again from coasting or idle. Appreciate your response.
PS The torque output is OK. Could it be something obout P and I settings?
No, just the direction detection via the PAS fraction is irrelvant.
Code:
else { // torque sensor mode
			float_temp = (float) ui16_sum_torque;
			float_temp *= ((float) ui8_assist_percent_actual / 100.0);
			if (flt_torquesensorCalibration != 0.0) {
				float_temp *= flt_torquesensorCalibration / ((float) ui16_time_ticks_between_pas_interrupt_smoothed); // influence of cadence
Please log the output in debug mode, then we can see what happens.
regards
stancecoke
Hi! Just wondering which settings I could play around with to attempt to improve efficiency.
Right now the power consumption sits at 14-16amps (700-800w) at 35km/h. I average between 23 and 26wh/km, which is rather high compared to my previous speed-pedelec which averaged 12wh/km at similar speeds on the same trip.
Hi,
If I've understood the interactions of this software's features correctly then there seems to be an obvious way to effectively adjust "assistance level" without using a display.
But I'd really like to know for sure before launching into my first e-bike build on false assumptions and being disappointed.
As I understand it there’s three* means to modulate hub motor power on-the-fly with this firmware:
1. Varying “Assistance level” over UART
2. Varying pulse frequency on “PAS sensor” input
3. Varying voltage on “Throttle” input
If you want a sleek control system without display, throttle, or torque sensor, you need only retain PAS and accept the compromise of regulating power via cadence. It's too much of a compromise though, without a way to scale power to account for fatigue, weather conditions and terrain.
So how to scale power?
Conceivably by operating in "torque sensor mode" and using "throttle input" as a proxy for "assistance level" .
With the default “assistance level” set at 100% and “torque sensor mode” activated, wouldn't voltage on the "throttle input" be conceptually equivalent to "assistance level", due to power being mediated by cadence? i.e. assuming a hypothetical valid input range from 1-4V, 0V would equate to no assistance, and 4V to full assistance
(FWIW, I’d adjust the voltage signal by ditching front chainring shifting and use a spring return linear position sensor or cable-actuated hall throttle mechanism controlled by the ratcheting left gear shifter, in my case with a Campagnolo shifter resulting in nine distinct locked positions across 15mm of cable pull).
* not including the ability to move the motor into different parts of its power band by altering wheel RPM via rider power input and/or aerodynamic profile
The main parameter is the motor specific angle. You can vary it e.g. in steps of 5 to find the best setting.
If you have a ZWS type or a 12 or even 18 FET controller, that has the ACS712 sensings pads shortened, you have to disable the option Enable rotor angle correction. You can solder in the phase current sensor / remove the solder bridge from the sensor for best efficiency of course.
glennb said:
If I've understood the interactions of this software's features correctly...
Honestly I don't understand your post. Do you have a specific question?!
regards
stancecoke
Sorry, I can ask differently …
Is it correct that in “torque sensor mode”, voltage seen on the controller’s throttle input is converted into a weighting factor or multiplier?
I was imagining a use case without display or torque sensor, where the rider regulates this voltage with a handlebar-mounted static control such as a potentiometer. That way you could ride in whatever cadence is comfortable, and command more or less "assistance" by adjusting this voltage.
OK, still the motor power would be depending on the cadence. This sounds like a very strange setup. :?
I suggest to remove the spring from a normal thumb throttle. Then you get your wanted behaviour even with the stock firmware.
regards
stancecoke
Code:
regards
stancecoke
Okay so cadence does have proportional influence on the assist.
In regards to motor not starting i think it could be low voltage protection but also the use LCD4 display (need to test it more). During the testing i did not noticed how low is the battery and now on full charge and bluOSEC adapter there is no cut off on .
I do have similar question to what @Corrida victim has mention about power consumption. The current limits are:
Batt- 7A
Phase - 20A
Assit 1 - 20%
Dynamic assist - enabled
So how it is possible that on Assit1 the battery curent can go up 3-4A if this is 20%? Is the assist level based on Phase current then? Should i lower the Phase current to 10-15A to get best results with Batt current limit @ 7A?
Please don't mix up torque-simulation mode and torquesensor-mode! In torque-simulation you define specific current steps with the assist level. In torquesensor-mode, you define the gain of your human power with the assist level. So even in level 1 you can reach the Battery Current max value if you are pedaling hard enough.
regards
stancecoke
I seem to have a different sensor.
The markings I seem to spot are: A 750 1932 865A
For some reason I feel no difference when it comes to noise and power consumption when I disable "motor angle correction". Probably means FOC didnt work from the start, explaining my poor efficiency?
Hi guys
Today, I installed the custom firmware in my controller! It was pretty successful, I managed to get the firmware on the board and the app working.
However, I am using the potted 9-fet controller from topbikekit, so I was unable to access the backside og the board for soldering. Unfortunately, I destroyed one of the eyelets of the board when I tried to solder. I managed to get the firmware on there by just sticking in a Wire and and running the program, but I would like to repair it.
Dora anyone know how to repair such a board?
Yes, this seems to be an Allegro ACS72981 like sensor:
acs72981-product-image.ashx
You can try to desolder the 0.5 mOhm resistor (marked with "0m50"), then the ACS "sees" more current. But you have to consider the maxmium rating auf the ACS.
Have you looked at the waveform of the phase current in the BluOSEC-app?
regards
stancecoke
That's the brand indeed! Thanks for sending me in the right direction! I'll try finding the correct datasheet. But I'm afraid I'll have to leave the resistor as my phase current is currently set at 140amps.
I did indeed! Sometimes there is a nice waveform, sometimes there isn't, not sure what to make out of it.
On a sidenote, sometimes my bike just accelerates forward without pedaling. Braking with the brake that's connected doesn't seem to have an effect for at least a couple seconds. Not sure if it's hardware or software related.
The waveform looks good and the correction value is varying with speed and load. That seems to be OK.
Have you checked the battery consumption with a powermeter? Perhaps just the current calibration is not correct.
It is known, that the firmware freezes sometimes with BluOsec. In the branch "Torque from X4" we have replaced the computationally intensive float operations with integer arithmetic and shifts. This solves the problem, but we have never merged it to the master...
regards
stancecoke
