parabellum
Be careful, even 20-30C Turnigy LiPos heat considerably at continuous 5C discharge at the end of the cycle. Not sure if it is enough to melt heat glue, but it is already warm where you live. Anyway, tight box will solve that.
Samsung has been making INR cells for at least 3 years now. I have several INR18650-13Q (1300mAh) cells. They do fine and deliver full capacity at 3C, but not at 5C. At 5C they get real hot and only deliver 1000mAh (77%).liveforphysics said:If Samsung is making NCA cells now, they've joined Panasonic as the first two I've heard of making the switch so far at a level where they are actually making meaningful volume production rather than just BS datasheets and engineering samples but no real production volume.
And got this:From: "eBay Member: supowerbattery111" <supowe_gq6306uatx@members.ebay.com.hk>
Reply-To: supowe_gq6306uatx@members.ebay.com.hk
To: mitch*****@comcast.net
Subject: supowerbattery111 sent a message about HID Battery Samsung 20A 18650 20R INR18650-20R
We were unable to deliver your message to
For your safety, eBay does not allow the exchange of email addresses in member to member communications . This protects both buyers and sellers by keeping a track record of communications. It also helps ensure that transactions happen on eBay so buyers and sellers are covered by eBay protection programs.
Please remove the email address and resend your message.
If you want to receive photos from another eBay member, you do not need to share your email address. Buyers and sellers can now attach images to messages sent from eBay by using the “Attach Photos” button.
In order to send your photos, you need to be able to receive HTML-formatted emails from eBay. This can be changed in communications preferences in the account settings section in My eBay.
Thanks for their address and starting this thread.migueralliart said:Mitch,
This is their email address supowerbattery@gmail.com
Mention to them that you're from endless sphere. Also they always ask me to go thru eBay for the final transaction since that way your covered thru PayPal.
Let me know if I can help.
At the same time I asked for a price for 1,200 cells. Its more convenient to correspond via email. I'll post the price when I get it.Features:
-Special edition of Solar Force L2 Host in Mil-spec type III hard anodized in black
Features:
* Flashlight host (head assembly + battery tube + tail switch assembly) without built/drop-in
* Made of aluminum alloy
* Can use either a LED (Cree/ IR/ UV)-reflector or an incandescent (Xenon) bulb-reflector module
* Different functions depending on the Cree LED module being used: single or multiple output levels
* Uses both primary (CR123A) lithium or rechargeable li-ion (16340 or 18650) batteries (not included)
* Tail clicky switch
* 97 grams (without batteries)
* Length x diameter (head and battery tube, mm): 140 x 32 x 25
circuit said:$7 for 2Ah cell is $3.5/Ah, which is 3 times more expensive than other quality cells... A bit too much.
What are the specs, chemistry? Where did you get them?ttkc said:Wow, that's so expensive. I can never afford that. I built my battery using 20 of these
They came spot welded in 1s3p so assembly is quick and mininal. Each pack cost me $9.00 for 7.2Ah or 26.64Wh. They don't have the high discharge rate but was more than enough for my ebike and only cost a third of your cell price. Of course, I would use your cells if I wanted a race bike, but for now I only need a regular ebike, plus my budget just won't allow it at this moment.
Why am I not surprised. This is my third post on this board but I'm not a newbie. I have worked with laptop cells long enough to tell who really knows what they are talking about. And you don't. I have been reading this forum for a long time and I know you so well. You wait for a new comer and intimidate them with your make believe knowledge. It won't work with me. So stay away before I unmask you with your countless stupid advices. Now, let me go back to the real discussion with real adults.dnmun said:also there is no cardboard insulator under the parallel strap. if you look at how the end of the strap is cut so there is a sharp corner right above the thin plastic insulation of the case, it is just waiting to cut through the plastic and short out that row. this is why the Vpower packs fail.
those cardboard insulators must be so cheap and yet the guys who spot welded that 1S3P decided they could do it cheaper. but once they are sold they don't have any responsibility for the cells.
Yes. That is the safer way to connect the cells if they are to be used in a rough environment. It's not necessary in laptop batteries. Before I bought these 1s3p packs, I had disassembled close to a hundred laptop batteries from Compaq, HP, IBM and Toshiba. Some of them do have an extra paper tape ring around the positive terminal, most don't. I am sure billion dollars company like IBM, HP know more about these things than that silly dnmummy or whatever the heck his name is.spinningmagnets said:Here's a pic showing proper insulation under the strips:
These packs are removed from new overstocked Dell laptop batteries. I have seen the exact same cells in HP batteries as well. But they are not Sanyos. If I remember correctly, the seller told me that these are generic cells made in Japan that are bought and used by laptop manufacturers as a second source supply. My pack is a 10s6p, so 14.4Ah. It weighs exactly 6 lbs before the connectors and balance wires. I use it with a 350W front geared hub and a 17A controller. It's been six months now and I have no complain. Here's the amazing thing: I balanced the pack when it was built. I only bulk charge it (to 41.0V). I check the balance every two or three charges. It's still balanced today, after about 50 cycles. So no manual balancing at all, so far.migueralliart said:Those look to me like sanyos . they can't handle 2c so you need a slightly bigger capacity than your controller current rate.
I'm sure most of us want a friendly, supportive exchange of information and opinions. Please don't post those kinds of useless, unnecessary and uncalled for insults on this board.ttkc said:Why am I not surprised. This is my third post on this board but I'm not a newbie. I have worked with laptop cells long enough to tell who really knows what they are talking about. And you don't. I have been reading this forum for a long time and I know you so well. You wait for a new comer and intimidate them with your make believe knowledge. It won't work with me. So stay away before I unmask you with your countless stupid advices. Now, let me go back to the real discussion with real adults.
These cells are removed from new overstocked Dell laptop batteries. So I guess they are typical Lithium Cobalt. I'm working from memory here. I think the seller said 0.5C continuous and 2C burst.parabellum said:What are the specs, chemistry? Where did you get them?
Agree. That's $0.95/Wh. And from my experience with the Samsung INR18650-13q cells, I don't think it can do more than 3C continous.circuit said:$7 for 2Ah cell is $3.5/Ah, which is 3 times more expensive than other quality cells... A bit too much.
ttkc said:Why am I not surprised. This is my third post on this board but I'm not a newbie. I have worked with laptop cells long enough to tell who really knows what they are talking about. And you don't. I have been reading this forum for a long time and I know you so well. You wait for a new comer and intimidate them with your make believe knowledge. It won't work with me. So stay away before I unmask you with your countless stupid advices. Now, let me go back to the real discussion with real adults.dnmun said:also there is no cardboard insulator under the parallel strap. if you look at how the end of the strap is cut so there is a sharp corner right above the thin plastic insulation of the case, it is just waiting to cut through the plastic and short out that row. this is why the Vpower packs fail.
SamTexas said:Agree. That's $0.95/Wh. And from my experience with the Samsung INR18650-13q cells, I don't think it can do more than 3C continous.circuit said:$7 for 2Ah cell is $3.5/Ah, which is 3 times more expensive than other quality cells... A bit too much.
I bought six A123 20Ah (actually 19.5Ah) pouches for $30 each. Made in USA, not sure if that made a difference. That's $0.47/Wh. The pouches actually deliver full capacity at 5C (100A). I really wanted to test them at 10C, but I lacked the necessary equipment. At 5C, there is virtually no voltage sag and the pouches are barely warm at the end of the discharge.
