New firmware for TSDZ2 motor, 850C and SW012 displays
Version: 850C_SW102_v0.6.8, download here.
Videos showing 850C display and SW012 display:
[youtube]eDENZS4pHvo[/youtube]
[youtube]q0N5W3Fgyjk[/youtube]
Changelog:
- No more motor unwanted startup at power on or when leaving the configurations menu (the motor initialization is now much more robust).
- Now user get errors if TSDZ2 firmware version is incorrect, if brakes are pressed at startup or if RX or TX communication is missing - this will help a lot when users by mistake exchange the TX and RX wires or some bad contact of that wires.
- Assist levels are now 20 (previous were 9). I ride on the city at motor max power and so I need hight assist levels AND I also do MTB and there I need fine control and low assist levels, now I will be able to use for instance the assist levels from 1 to 10 for MTB and the 10 to 20 for riding on the city.
- added 3 main screens were each screen have his own customized numeric fields and on 850C has also his own customized graph.
- UP and DOWN buttons are now really fast responsive and predictive as everyone expects (I had to remove the click + long click detection on this buttons and anyway, seems this type of click is hard for users to understand and do).
- SW102: the assist level value is now shown on the wheel speed field by override his value during 2 seconds when changing assist level (this means assist level is now hidden). Also at startup it is shown for a few seconds.
- SW102: changed battery symbol to be similar with the design specification as also the 850C battery symbol.
- Improved the Colomb counting based SOC by considering the amount of power loss on the battery internal resistance and cables.
- The amount of power loss value on the battery internal resistance and cables can now be seen on configurations.
- Removed battery voltage SOC based on voltage and so the focus will be on the much better Colomb counting based SOC.
- SW102: corrected the numbers where the "." and ":" were not being shown.
- Motor PWM value is now shown from 0 to 100 instead of the previous 0 to 255.
